Carburetor Float Question
Kevin
12-26-2003 15:28:05
I'm not much of a mechanic but learning, so here goes. The float on my M carburetor is stuck - I think. When I try to start it gas pours out the bottom of the carb. Can I unstick the float without taking the carburetor off or do I need to take it off to try and fix it. If it isn't the float I suppose the next step is to rebuild the carburetor. Thanks for any help. It's 70 degrees here in Texas and feel the need to drive the tractor.
Mr. J....maybe another pr
12-26-2003 19:45:04
 Re: Carburetor Float Question in reply to Kevin, 12-26-2003 15:28:05
third party image
Kevin,
I think you may also have a bad needle and seat. This is the valve that keeps fuel from flowing when the float moves up. Many times the needle can become dry and crack, allowing fuel to flow through even though the float is rising. Another problem, that I have seen a couple of times is a cracked bowl or top....a very microscopic crack can leak fuel and it will drive you nuts....Anyway, I would go to your local IH dealer and pick you up a carburetor kit, put in a new needle and seat, and while you have it apart, place the float into a container of gasoline and see what happens, if it floats, then great. Re-assemble the carb and install it...I hope this helps, hope you all had a Merry Christmas. Let me know if I can be of further assistance,
Jared Jeffries
rebuilder
12-26-2003 16:27:12
Kevin: These are the most common problems with floats on carburetors I rebuild.
1) The float has fallen apart either from excess vibration or excess heat melting the solder.
2)the float does not "float" due to a pinholeleak or a crack in the solder. Shake the float itself and you will feel gas moving inside the float. I have tried to drain and resolder floats with no luck and besides you can generally buy a new float fairly cheap.
3) I have found the float tends to "stick" along the sides of the carb. Fisrt thing you need to do and the last thing you do after a rebuild is to twist the carb. in your hands. You should hear or feel the float moving. If not take apart and CAREFULLY bend one or the other sides to adjust the fit, then assemble & twist again.
4) many older carbs. will be rusty or sticky enough from varnish to cause the float to stick on the pivot axle. Make sure float & needle valve combo move freely.
5) if after rebuilding the carb you still have gas leaking out, many times this can be fixed by bending the float down slightly so it will shut the fuel off sooner.
6) make sure you have the pivot bracket sides close but not tight against the float and that the axle "IS" tight by clamping with the split end of the pivot bracket.(I found out the hard way by having a 300 carb that I rebuilt cause a gas fire. Luckily the fire was put out without too much damage and the tractor in question just happened to be owned by a relative"WHEW". Near as I can tell on the carb I rebuilt I did not get the float axle clamped tightly enough as well as the pivot bracket sides were to far apart. Vibration etc. caused the float axle to slide out and the float "fell" cockeyed into the bowl which in turn cused the fuel to gush out hitting a hot motor and starting the fire. Thank god it was put out quickly, but I had some serious questions about my ability thrown my way. I guess that is one way to learn!!
If you have any more questions thow a post my way. Merry Christmas & happy New Year.
deereeater
12-26-2003 15:47:56
bust thing to do is take the carb off and chech it out the most you may have to do is soak it in cleaner for a day or two. or the float could be bad and only need a little sodering.
Mark in AB
12-26-2003 16:05:10
 Re: Re: Carburetor Float Question in reply to deereeater, 12-26-2003 15:47:56
tap the carb with a bolt or small hammer while the fuel is overflowing. flooding may stop if your real lucky
FARMALLSM
12-26-2003 17:34:00
 Re: Re: Re: Carburetor Float Question in reply to Mark in AB, 12-26-2003 16:05:10
SOLDER MELTS AT APPROX 800 DEGREES I DON'T WANT TO BE AROUND A CARB OR TRACTOR FOR THAT MATTER THAT IS SUBJECT TO THAT MUCH HEAT. IN ORDER FOR THE SOLDER TO MELT ON THE FLOAT THE TRACTOR WILL HAVE TO BE ON FIRE. GOOD LUCK
moonlite
12-26-2003 17:51:17
 Re: Re: Re: Re: Carburetor Float Question in reply to FARMALLSM, 12-26-2003 17:34:00
50/50 solder flows freely at about 400F I have soldered many fuel tanks and other fuel vessels without any problems. Was a sheetmetal worker!
rebuilder
12-26-2003 17:40:58
FarmallSM: You would not believe how many floats/venturi I have to replace each year due to melting. Usually from burned tractors, although I have seen where excessive backfireing DID seem to cause some partial melting to the float. Sometimes you have to see it to believe it.
