Sludge in Hyraulic System
Rob A.
12-26-2003 20:03:20
I bought an old IH 434 tractor.When I changed the hydraulic fluid,the filter screen was almost blocked solid. When I drained out the reservoir,I noticed about 3/8 inch of sludge throughout.I reached in the hole with whatever I could and scraped a small portion out. Is there something I can put in the system to flush it? Or would the freshly dislodged dirt/sludge ruin the hydraulic pump right away?
Brian
12-27-2003 17:58:47
 Re: Sludge in Hyraulic System in reply to Rob A., 12-26-2003 20:03:20
Used to see that once in a while when I worked at a IH dealership. We would spray, slosh as much diesel fuel as we could around the inside,let it sit for a while, drain it, do it again. Then fill up the rearend with a 1/2 mixture of diesel and Hytran,new filter, then run the tracter for a while and get the hydralics good and warm. Drain it and refill with Hytran and new filter. Run again and check the filter and replace it. Never lost a pump doing it that way.
Haas
12-27-2003 15:51:03
Never had much luck getting sludge to dissolve by putting in diesel fuel or kerosine and just letting it set. I suggest getting a big pump type oil can with a long flex spout on it and filling the can with diesel fuel or kerosine.(Please don't use gasoline, it's a fire and health hazard!) Use the flex spout to get around the parts in there and squirt the solvent to wash the sludge out the drain hole. A bit tedious, but with patience, I think you can clean out most of the sludge.
old
12-26-2003 20:38:51
You might try diesel fuel to remove some of the sludge but don't run it with the diesel in it just let it sit for a few hours
Brown Dirt Cowboy
12-26-2003 20:54:32
 Re: Re: Sludge in Hyraulic System in reply to old, 12-26-2003 20:38:51
Old, would it maybe help if Rob A. was to rock this tractor back and forth a bit to slosh the diesel around to dislodge more of the sludge before draining it? Just a thought. Tom
old
12-27-2003 08:15:23
 Re: Re: Re: Sludge in Hyraulic System in reply to Brown Dirt Cowboy, 12-26-2003 20:54:32
Ya if he jacked it up and would spin the wheels that would probably help a lot
