Farmall A: Needs more power!
Jim V
12-26-2003 21:07:05
Can you put domed pistons in an A? Using the stock
head. Tractor is 1946 year, engine serial 356318
Thanks, Jim V
Brown Dirt Cowboy
12-27-2003 18:49:29
 Re: Farmall A: Needs more power! in reply to Jim V, 12-26-2003 21:07:05
Jim V. After you put in the domed pistons turn them RPM's up from the stock 1450 to 1650 or 1700 and see the difference. Maybe just turn up the RPM's before you put in the pistons. The difference between the motors on the A the B and the early C tractors 200RPM's same 3x4 bore and stroke. Try it unless your A is ready to be rebuilt it may help. Tom
Will Sick
12-26-2003 21:24:26
I have a B farmall with the same 113 enginine with domed pistons.It is a snappy little tractor.
