F12 or F14 Tractor
dw
12-27-2003 08:47:20
I came across an F12 or F14 abandoned tractor, recently. It had a gear box, of some type, between the engine and transmission. A rod went from the gear box to a small lever, which was by the transmission. Was this a step-up transmission of some sort? Tractor also had a single front wheel set-up. Was this rare for the F12 & 14 series?
Just curious.
Bob S
12-27-2003 09:30:35
 Re: F12 or F14 Tractor in reply to dw, 12-27-2003 08:47:20
The gear box you are describing is a step up transmission since 3rd gear was topped out at 3&1/2 MPH on the F12 without it. I don't know about the single wheel but the trans is a valued item to have. Bob
