SMD thrust bearing
49 Cubber!
12-27-2003 13:11:14
Mine is wore out pretty good.What are my options on it and I did manage to get one piston out and it was scratched up pretty bad so if i can fiqure out what to do on the bearing,Ill need new pistons.Ill post a pic of the bearing as soon as I can.
49 Cubber!
12-27-2003 18:05:56
 Re: SMD thrust bearing in reply to 49 Cubber!, 12-27-2003 13:11:14
Heres some pics of the lower thrust bearing.the captions will explain,to the best of my ability,the problems with this bearing.The other main caps I have pulled have some wear on them but not like this one and I wonder if it was not replaced and the others were.The rod bearings I have been able to get out looked normal,no major scarring ot scrathing,just wear.
