A Oilpump
Jim
12-27-2003 19:50:43
When I re-installed my "A" oilpump in the new block it did not seat like it was in the old cracked block. I am thinking it will not produce enough Oil pressue if it is not seated tight in the block. Any sugestions?
gene b
12-28-2003 03:13:59
 Re: A Oilpump in reply to Jim, 12-27-2003 19:50:43
You better recheck your work as they will fit the same and if the bolts go in that hold it in place what are you worring about? Did you have it apart and was the head warped. New one are avail for 63.
Jim
12-31-2003 10:16:34
 Re: Re: A Oilpump in reply to gene b, 12-28-2003 03:13:59
The Oilpump is in fine shape. The problem is it was seated good when I pulled it from the Old Block now when I put it in the new block it needs to go 1/8" deeper to seat than it is allowed to go because of the way it bolts to the side of the block. In other words I seat it and then pull it up 1/8" (engine upside down)or so then put the bolts in I plan to see how many thousands it is off seat while bolted to the block as it should be. WHY IS IT DIFFERENT FROM ONE BLOCK TO THE SECOND? It is not seated and will be loosing lots of Oil pressure!
