Specific casting date?
SGT K
12-28-2003 05:51:24
I recently acquired a IH H for restoration. The serial number is 27XXXX, which, I believe, makes it an early 1948 model. The casting letters are R's, except for the rear-end, which is a Q. I'm thinking when I buy it, "looks good, nothing terribly suspicious here." After I get it home I find a specific date cast on the operators platform. The date is the same size as the other casting numbers and reads, "1-28-48". This date is cast between the oil fill plug and the brake lock on the platform close to the left rear brake. Has anyone else seen a specific date cast here before? I am sure several of you have much more experience than I do, and I'm wondering why I've never seen this, and what it is for.
Thanks
SGT K
12-30-2003 06:38:48
 Re: Specific casting date? in reply to SGT K, 12-28-2003 05:51:24
I hope everyone doesn't think I'm getting to carried away with this casting code business, but I found something else sort of neat. Stenciled on the right side of the raditor, about 12 inches long and an 1 1/2 high, is the date 1-22-48. It looks like it might have been stamped into the black paint when it was still wet. I was going to re-paint the radiator, but now I think I'll leave the sides unpainted, since its under the sheet metal anyway. None of this makes my ordinary H worth a lot more money, but I'm sure having a good time. Does anyone else know where there might be dates stamped, stenciled, or hidden on these Farmalls.
Farmall Dude
12-28-2003 10:47:14
Hi, as long as you're into casting numbers! On the H block, there is a number just below the firing order number and mine is 9*9*J. What is that? Also, if a tag # FBH 3XXXX6 is the same as the # on the block, that is the original engine, right?
Thanx!
CNKS
12-28-2003 10:57:56
 Re: Re: Specific casting date? in reply to Farmall Dude, 12-28-2003 10:47:14
Sept 9, 1940. Engine and chassis serials don't have to match, although on one that old, they may be pretty close. But, if your chassis serial starts with a 3 and has 6 digits as you indicated, it could be anywhere from a late 1948 thru the end of production, depending on what the other numbers are. With five digits beginning with a 3 it is indeed a 1940.
Farmall Dude
12-28-2003 15:33:57
 Re: Re: Re: Specific casting date? in reply to CNKS, 12-28-2003 10:57:56
CNKS: Thanks for the come back! Listen, I made a mistake on the chassis #, I was thinking of one of my other ones. Its FBH 423x6. Now, thats the same # thats on the engine block too. The 9*9*J means it was Sept 9th 1940. Right? Would that mean that its a 1941 H? Oh, I want to thank Mike in Canada, for the come back on me playing with the Cubs mother, the H :>) I didn't get a chance.
This is the best place in the world, to come to for answers for the big iron. (Red) Green, is okay too, they ARE Farmalls, just not ripe yet. :>)
Thanx!
CNKS
12-28-2003 17:38:08
 Re: Re: Re: Re: Specific casting date? in reply to Farmall Dude, 12-28-2003 15:33:57
I assume the x means you can't make out the digit. Then it is a 1940, which agrees with the Sept 9, 1940 casting number. You confused me at first because X6 means low speed gears, but the first H had serial FBH 501.
Farmall Dude
12-28-2003 19:50:19
 Re: Re: Re: Re: Re: Specific casting date? in reply to CNKS, 12-28-2003 17:38:08
Yes, CNKS it l@@ks like it could be a 3 or 8 ?!
I should have put FBH 423?6. Sorry about that! Okay, what does FBH stand for? Oh, if you come back to the old post's!!! Will a 300 carb, fit an H ?
Thanx!
CNKS
12-28-2003 09:32:42
Perhaps Guy Fay will correct me, but I think for some reason IH put that only on the transmission cover instead of 1*28*R.
From Guy Fay book.
12-28-2003 10:36:12
 Re: Re: Specific casting date? in reply to CNKS, 12-28-2003 09:32:42
"Casting codes seem to follow two formats. The first is just the straight month, date and year (12-3-36) for example. These codes are found infrequently, seemingly without pattern, although W 30s from the mid-1930s often show this code on the engine block"
Nebraska Cowman
12-28-2003 07:58:59
yes I have seen several Ms marked on the cover like that.
SGT K
12-28-2003 08:09:09
 Re: Re: Specific casting date? in reply to Nebraska Cowman, 12-28-2003 07:58:59
I still wonder why? I don't know anything about casting, but I wonder, was it the first cast of the day? Or maybe the first time the mold was used after changing something? I'm sure the same answer for my H would apply to the Ms you've seen.
CNKS
12-28-2003 11:09:50
 Re: Re: Re: Specific casting date? in reply to SGT K, 12-28-2003 08:09:09
Again, it simply means that the transmission cover was made on Jan 28, 1948, and it fits in very well with the R's (1948) on your other castings, also the Q (1947). You will have to ask some of the deceased engineers why that format is found only on your transmission cover.
Guy Fay
12-28-2003 10:57:13
They put a small tag on the patterns to denote the day that the piece was cast. On some later castins, they even put a small dial to tell you which shift it was cast on. Trivia fact, next time you've got some time to kill in a porta-potty, a lot of them have the same kind of casting dates and times for the plastic parts.
SGT K
12-30-2003 06:49:44
 Re: Re: Re: Re: Specific casting date? in reply to Guy Fay, 12-28-2003 10:57:13
Guy Fay!! I just realized that I have you book at home on the Farmal Letter Series! I realize I'm showing my Farmal ignorance here, but I have been amazed at all of the useful information I've received from this discussion board from all of the people that help answer questions. This is great.
NDS
12-28-2003 06:24:29
Yes have seen several "specific" dates from late fortys most that I have seen have been on torque tube though. Do not know why this was done.
