up grade from gen to alt on 350 utlility
Donald L . Anth
12-29-2003 05:00:30
I have a 350 utility with 12v gen system how do i go about converting to a delco alternator? fabing brackets is not a problem. I'm in this for the long haul and would like to add lights and the such. Any help ? Don
deano
12-29-2003 09:09:41
 Re: up grade from gen to alt on 350 utlility in reply to Donald L . Anthony, 12-29-2003 05:00:30
take a look at an article "step by step 12-volt conversion by bob melville..i think you can get there by...http://www.ytmag.com/articles/artint195.htm there are a lot of good articles and diagrams on 12 volt conversions. made life easy for my conversion...the biggest reason i switched is cost. i like the idea of sticking with 12volt with all my tractors/equipment, since i have more machinery than batteries, i am swapping out alot...
deano
12-29-2003 09:16:25
 Re: Re: up grade from gen to alt on 350 utlility in reply to deano, 12-29-2003 09:09:41
didnt catch that you are already 12volt..may not apply in your case..
Hugh MacKay
12-29-2003 08:10:54
Donald: I presume your system is already neg ground. If not you will have to use neg. ground. Just a matter of putting battery other way and reversing wires to amp gauge. You will find you have an extra wire in your harness. I always use that for an excite wire and use a push button type switch to activate. Push button switch important so you will not forget and leave on when tractor is not running. I also like to use a dual pulley on alternator, from a V8 Buick or Olds. This give gives a bit more leway in mounting as you can use either pulley.
Don't be discouraged by the nay sayers, alternators are less expensive, charge better, etc. I have 3 of these going, one 6 volt and two 12 volt. My tractors start better, run better and ignition components last longer. If you need more info send me an e mail.
Mark in AB
12-29-2003 18:12:02
 Re: Re: up grade from gen to alt on 350 utlility in reply to Hugh MacKay, 12-29-2003 08:10:54
When you convert to negative ground don't forget to swap wires around on your coil, still might work, lot less power though.
artie
12-29-2003 05:42:44
whats wrong with a generator?
