How to Idle W-30 Down
Alex
12-29-2003 13:04:31
I have a 1935 W-30. It runs good but idles fast any ideas how to slow down. No Idle screw on carb. Any help would be greatly appreciated.
Thanks
Alex
Nebraska Cowman
12-29-2003 17:37:26
 Re: How to Idle W-30 Down in reply to Alex, 12-29-2003 13:04:31
that is what the throttle is for. can't be yours is working
Andy in Ohio
12-29-2003 15:37:31
If I cant lower it by using carb screws, try the governor. Loosen the two screws at the 90deg.knuckle and pull up or down, this works on Hs and Ms. Should work on yours if its close to the same setup. Good luck
12-29-2003 14:04:05
That's not the purpose of the "idle screw" on a carburetor anyway.
