Rim rivets
Don
12-29-2003 19:04:02
Hi! I got a rim with riveted lugs. Rim is rusted out. I got a good rim with bad lugs, want to remove lugs and put on good rim. They are riveted. How can I put them back on? 1/2" rivets, bolts or what? Where can I get rivets that large? Thanks for any advise. Don
John in Ne.
12-30-2003 10:49:52
 Re: Rim rivets in reply to Don, 12-29-2003 19:04:02
Heres what I did on my 'C',I ground the rivets off on the inside of the wheel.Then I knocked the lugs off of one wheel and put them on the other,I then welded the rivets back on,on the inside of the wheel.It should be just as strong as the rivet,and no weld is showing on the wheel.John
Don
12-30-2003 19:00:32
 Re: Re: Rim rivets in reply to John in Ne., 12-30-2003 10:49:52
Thanks! That just might work. Didn't think of that. Don
E J
12-30-2003 09:51:17
Would thier be any thing wrong welding them back on?
TDK
12-29-2003 20:17:07
Try M.E. Miller Tire(www.millertire.com).They probably have what you need.
