H carb - choke lever ball seat
Dave in CT
12-29-2003 20:38:49
Thanks for the id on the ball that holds the choke lever on my D10 '47 H carb. There's a depression in the original piece where that ball rode. There is no depression in the rebuild kit part. Did this depression appear because of wear or was it part of the original manufacture to hold the choke plate open? If so I guess I need to drill a small depression to duplicate it.
Thanks,
Dave
rebuilder
12-30-2003 15:06:34
 Re: H carb - choke lever ball seat in reply to Dave in CT, 12-29-2003 20:38:49
Dave:In most rebuild kits I have used, the choke lever does not have the dimple. I generally try to use the old choke levers and since I go through about 30-40 H carb.s/year I have an ample supply to use from the junked carbs that are not rebuildable.
Paul in Mich
12-30-2003 00:10:57
Dave, Most rebuild kits have the dimple in the choke lever, but if yours doesnt, I would suggest that you use a rounded off punch and smack the lever where the ball would match up in the choke off position. It may not be such an easy task lining the dimple up, but if you measure closely, I'm sure it will work. If all else fails, there is always the spring to the governor trick that I have seen on many many H's and M's.
Dave in CT
12-30-2003 05:52:33
 Re: Re: H carb - choke lever ball seat in reply to Paul in Mich, 12-30-2003 00:10:57
I figured I'd put some marking on the lever and work it, loosely assembled, with the ball pressing under spring tension, then drill a small dimple at the end of the ball-path mark.
