Timing Help!
Old Guy
12-29-2003 21:23:45
I just finished assembling my F-20 and I have been attempting to start it with only an occasional backfire along with it kicking me. I followed the instructions from the origional owners manual as best I could. Wondering if there is something that I could be looking over.
Kurow
12-30-2003 13:06:19
 Re: Timing Help! in reply to Old Guy, 12-29-2003 21:23:45
Had the same problems with my AV. I used the TDC mark on the flywheel as the guide for TDC but this proved to be wrong. Use the thumb over the spark plug hole and a piece of wire to manually find TDC. You need to be firing just after TDC not beforte (Hence the kick)
The Red
12-30-2003 09:18:11
I had a 1938 F-20 at one time. Setting the spark lever in the 2:00 position made her kick. Found out someone had adjusted the lever linkage so when the lever was in the 6:00 position, it was on top dead center. You might have to try the lever in different positions.
Nebraska Cowman
12-30-2003 03:42:21
well, if it was timed right it wouldn't kick you. so just go back over the instuctions. Sometimes it takes me several trys to get the disk in the right holes.
