X1 at end of serial # on H
pat
12-30-2003 10:07:23
someone asked this in the classifieds but I was going to ask here ,, I have a H and has the same X1 at the end off to the side of the serial # what does this denote ,, a certain add on???thanks pat
`pat
12-30-2003 16:12:22
 Re: X1 at end of serial # on H in reply to pat, 12-30-2003 10:07:23
thanks guys you may be right, I never thought of that, thanks for the info, I have 2 of these h's the one with the X1 is in pieces , but it does not have the hole in the hood so it is correct .. I dont know the yr of this one yet,, but I have another one that believe is a 1946 serial # 233591,, this one has a tank and a hole for the other fuel, but I dont believe it is hooked, there appears to be no valve on the bottom of this small tank, and once in a while water comes out,, thanks all pat
Dave
12-30-2003 13:09:32
I belive fellow that asked question on ads is realy wanting someone to ask if its for sale.
SGT K
12-30-2003 10:41:01
X1 Denotes the tractor was equiped with a gasoline engine. X3, for example, would indicate kerosene. Guy Fay has a list of these in his book, FARMALL Letter Series Tractors.
Bill Smith
12-30-2003 10:37:04
The X1 at the end of serial number I believe indicates that the tractor was equiped with a gasoline engine from factory. The H was also available with a kerosene and a distillate engine. The kero's and distillate's had a little different head, manifold, (jets) in carb, extra reserve gas tank, and radiator shutters. They also had an extra hole in the hood to fill the little reserve gas tank that was under the hood, right side in front of main fuel tank. Check it out, I bet the hood doesn't have the hole unless the hood has been changed.
