15.5s on 12 rim
Ron Klemp
12-30-2003 10:44:19
I know it's not orthidox, but can I get away with 15.5s on my 12" rear rims?
fergfarm
12-31-2003 21:51:35
 Re: 15.5s on 12 rim in reply to Ron Klemp, 12-30-2003 10:44:19
use the 12,s I would.I would,nt buy new rims if I already had them. It,s not what the book says .
If you don,t want to use the 12,s ,what do they fit i,m lookin for a aset for my H. e-mail me.
klf
12-30-2003 16:26:00
That tire is way too big for that rim. A 12" rim should have a 13.6 tire. A 15.5 goes on a 14" rim. With the combination you have, there is the risk of the rim cracking. Also, you are going to be running on the center of the tire, which doesn't give you full traction. The biggest size I would go on a 12" rim is a 14.9.
Bill Smith
12-30-2003 11:04:45
Seems like I got an either 14 something or 15.5 on a 12. Bought a tractor that way. Had the regular sized tire on the other rim. I chose to not use the tires simply because of the size difference between the two. The tire looked like it would of worked O.K. but clearly looked oversized for the rim. 12.4 or something about like that would fit and look right.
