water pump pulley
Buster
12-30-2003 13:45:45
On a Farmall 100 how do I get to the bolt to tighten the pulley, there is just no romm. Help!
F-man
12-31-2003 12:45:39
 Re: water pump pulley in reply to Buster, 12-30-2003 13:45:45
I assume you are talking about the tension adjustment. You need to take a 13/16 open end wrench and grind some of the thickness off so it will fit. Don't forget to add oil to the fan bearing.
