Super A Hydro capacities
DG
12-30-2003 16:14:33
Rebuilt the entire unit and need to know the capacity of the hydro fluid including plumbing and pump, or do I just fill it to the top of the fill hole?
Gary_N_WV
12-30-2003 18:13:48
 Re: Super A Hydro capacities in reply to DG, 12-30-2003 16:14:33
About 8 1/2 pints.
Book says:
Fill the reservoir, Start the engine, run at about 650 rpm with the filler plug removed, work the control levers back and forth 10 or 12 times, then place the levers in the rear position and stop the engine.
Add fluid to bring the level to within 1/2 inch of the filler opening.
Hope this helps !
Gary
