Farmall A 1941 model steering box parts
walter Bobruk
12-30-2003 17:45:36
Where can I find parts for MY tractor? Circa 1941
Farmall IH# A-FAA 45528 540...
I have IT shop Service manual, but no part numbers or leads on who has seals and bearings plus any gaskets needed to overhaul completely.
I will be a happy to contact anyone by phone at my expense for conversations of depth on the subject of the overhaul procedure. First need the parts to be sure I can put it back together and use it.
Jonathan Mirgon
12-31-2003 06:09:02
 Re: Farmall A 1941 model steering box parts in reply to walter Bobruk, 12-30-2003 17:45:36
I have rebuilt the steering box on my 1940 (a)
If you need help or information I can be reached at 740-569-4707 (Jon), or Mirgon@ohiohills.com
parts man
12-30-2003 19:27:00
Your local Case- IH dealer should have the seals etc for the tractor.
Jim
12-31-2003 09:50:07
 Re: Re: Farmall A 1941 model steering box parts in reply to parts man, 12-30-2003 19:27:00
I rebuilt the steering sector on my A, and replaced the square shaft & arm with a tapered shaft & arm. The parts I have could be remachined (probably) if you need some parts in hand before you tear it down.
