Farmall 560 question?
DEM66
12-30-2003 21:12:07
Will a 560 pull a 6 row 30" corn cultivator? I have 100 acres of corn to do 2004.
Thanks,
Dan
Heat Houser
12-31-2003 02:04:10
 Re: Farmall 560 question? in reply to DEM66, 12-30-2003 21:12:07
You will have enough power to handle a 6 row 30 cultivator. If it is front mount, nothing required. If it is fast hitch (rear) mounted, you will have to add some front weights.
Caseman
12-30-2003 23:57:36
I think it's more about the weight than how hard it will pull> Sounds too heavy to me. Much weight needed on front...?
F-man
12-30-2003 21:32:28
If you are referring to the old style cultivater that cultivtes between rows than yes it will. If you are talking about a 6-bottom plow than you may have problems.
