Will M draw bar fit a model 300 ??
Glen Thibodeaux
12-31-2003 05:54:51
Will a M roller draw bar fit a model 300? Any idea on the value of a complete M draw bar in good condition??
Thanks for your time,
Glen
CNKS
12-31-2003 18:27:24
 Re: Will M draw bar fit a model 300 ?? in reply to Glen Thibodeaux, 12-31-2003 05:54:51
I believe the swinging part for the M is longer, the U part should fit.
Will Sick
12-31-2003 18:43:58
 Re: Re: Will M draw bar fit a model 300 ?? in reply to CNKS, 12-31-2003 18:27:24
The u part will fit. The swinging part will not fit and the pin in the M swinging drawbar is bigger.The later M swinging drawbar is thicker and will not fit the bracket under the tractor unless you grind it out.
artie
12-31-2003 13:07:09
not without some refabricating
Donnie
12-31-2003 13:05:34
Yes it will fit. Done it on several occasions. The axle clamps are made a little bigger but will fit just find. A complete drawbar with swinging hitch around goes for about $150.00. Hope this helps
