H rollover ?
riverbend
12-31-2003 07:00:28
All these messages about safety got me thinking, Does anyone know how steep of a side hill you can work on before an H will roll over ? Of course, mine does not have ROPS and only having this one H, I don't want to try it myself to find out. Does anyone know where the center of gravity is on an H ?
Thanks
Greg
Hugh MacKay
12-31-2003 19:50:43
 Re: H rollover ? in reply to riverbend, 12-31-2003 07:00:28
riverbend: Best way to make all row crop tractors safe as possible is rear wheel tread out to 72"+ centers. From there add ballast and add it low. Calcium chloride in tires will lower the center of graviety better than any other source of weight. Wheel weights will also help. A Farmall H needs all three of these items. If you allready have them fine, if you don't, install them you will be surprised how stable the H can be. We need you on forum as well so exercise care.
I know there has been a lot of discussion on here about the damage chloride does to tractor rims. If your putting chloride in rear tires buy new tubes, with the threaded stems. At the first sign of leakage around the stems replace them. Rims we see rusted out from chloride have usually been parked in a shed for a number of years with slow leaks. If you have a flat and get chloride on a rim, wash it well before reinstalling tire and tube. Remember also most of those rusted out rims from chloride are 50 years old.
Jason
12-31-2003 15:37:18
If you feel un safe chances are you arn't safe!
Fred - Kansas
12-31-2003 08:09:56
Too many variables involved to say how steep of a hill it can handle. Type of tires, how far apart they are, implement being used, weight of the operator, wheel weights, etc., etc.
Best thing to do is go up or down the hill, rather than sideways.
Fred - Kansas
