Water pump belt adjustment on H, HELP!
Scott A
12-31-2003 08:45:18
I am trying to renew a Farmall H (Just sold my Ford Jubillee because the H is a better tractor). I need to replace the water pump belt but I can't get the waterpump pulley to turn to release the tension on the belt. I have sprayed break free on the pulley, and lossened the one jam screw also. I cant figure out how to hold the hub from turning and still turn the outsde part to adjust the tension. Any ideas? Thanx for your help!
The Red. One Word
12-31-2003 09:02:20
 Re: Water pump belt adjustment on H, HELP! in reply to Scott A, 12-31-2003 08:45:18
PATIENCE. :)
As inexpensive as belts are, I would cut the old one off. Then remove that jam screw and shoot lots of penetrate in that jam hole. That will spread around the threads. Don't pound too hard on that adjustable flange pulley. They will break.
steveormary
12-31-2003 10:35:05
 Re: Re: Water pump belt adjustment on H, HELP! in reply to The Red. One Word, 12-31-2003 09:02:20
You just think the H is a better tractor then the Jubilee.
No
12-31-2003 10:50:33
 Re: Re: Re: Water pump belt adjustment on H, HELP! in reply to steveormary, 12-31-2003 10:35:05
better tractor is probably the wrong term, the H is a REAL tractor.
steveormary
12-31-2003 20:05:41
 Re: Re: Re: Re: Water pump belt adjustment on H, H in reply to No, 12-31-2003 10:50:33
No? Well I think the Jubilee would be easier to mount and dismount. Especially when old art is hangin around.
Lee
12-31-2003 12:20:31
I've had H's, and if I had one today I would gladly trade one for a Jubalee--- my neighbor took a cutting torch and put heat on his IH pump ring, just enough to heat it but not enough to set the belt afire and it losened it so it could be adjusted. do it quickly.
