Mice in the clutch housing
Dave@NY
12-31-2003 19:51:13
Been toying around with a Regular that I resurected this last month.The clutch has always been kind of strange.Had already taken a lot of mouse nest out through the access hole.Today I pulled the clutch cover and shaft off.WOW!! Couldn't believe how much more nest there was tangled around everything.Also found a handfull of hickory nuts and two dead mice.The pressure plate,disc and flywheel look OK.The pilot bearing feels rough when I turn it and the bearing on the clutch shaft is loose.Put it back together anyway just to see how it would act.Much better! Have to add two new bearings to my list of stuff to get.
Hugh MacKay
01-01-2004 12:56:37
 Re: Mice in the clutch housing in reply to Dave@NY, 12-31-2003 19:51:13
Dave: Back a couple of weeks ago I was having trouble with mice attaching my Super A torgue tube. I sprayed at liberal application of penetrating oil in there, from both ends. He didn't seem to like that enviorment, thus moved on.
jeff
01-01-2004 11:49:45
There is NOTHING like mouse PEE !!
Haas
01-01-2004 06:53:50
The Mice love those clutch housing! They especially like the Farmall A, B, C, and similar tractors.
Nebraska Cowman
01-01-2004 02:57:06
take a cap off a quart oil bottle and push it in the timing inspection hole to keep those critters out.
Dave@NY
01-01-2004 04:33:11
 Re: Re: Mice in the clutch housing in reply to Nebraska Cowman, 01-01-2004 02:57:06
Did that already.Too bad someone hadn't pluged that hole years ago.Must be the enginers at IHC didn't know much about mice,shoulda put a ltttle sheet metal flap over it like the N Fords.
Tommy H
01-01-2004 11:18:23
 Re: Re: Re: Mice in the clutch housing in reply to Dave@NY, 01-01-2004 04:33:11
If yout alking about the hole i think you are, its supposed to have a clip cover on it. My C has them, the clip on, and pop off.
