Painted Black on a H
Gary V
01-01-2004 19:36:43
Restoring my H to close to original as possible and can you guys tell what was painted black. Fan blade
fan shroud
starter
Mag
gas cap
Radiator Cap Silver???
seat pan Did it have all black fabric on it???
Steering wheel All black or black with red spokes
Bill Smith
01-02-2004 15:39:20
 Re: Painted Black on a H in reply to Gary V, 01-01-2004 19:36:43
I agree with those that have stated that there really wasn't anything factory black. Except for a couple of givens such as rubber on steering wheel and so forth. I personally like the looks of it better with a few items painted black such as axles, p.t.o. shaft, lights, nobs, caps and so on. It really sets off the red and silver tractor with a little black. Alot of stuff probably wasn't intended to be painted red, but essentially got hit with a good coat of overspray.
Hugh MacKay
01-02-2004 02:02:06
Gary: Most of those black items you are seeing are replacment parts, for example, starters, generators gas caps. I would do a bit of checking on the radiator cap item, I can remember seeing new Farmalls on the lot with silver or chrome plated rad caps. This would have been very late 40s and 50s but letter series Farmalls.
I personally like the black replacment gas caps. I have them on all my Farmalls. I have red caps as well, and if the ocasion is right I use them.
CNKS
01-01-2004 19:50:54
The only black on an H is the steering wheel rim, distributer cap, and plug wires, along with the seat canvas if you have an early model. Even the fan belt had red overspray on it. NOTHING was actually painted black.
Gary V
01-01-2004 19:46:52
also ,was the grill screen painted red right along with the rest of the tractor or was it left galvinized
CNKS
01-01-2004 19:51:55
 Re: Re: Painted Black on a H in reply to Gary V, 01-01-2004 19:46:52
Painted red along with the grille.
gary v
01-02-2004 19:41:31
 Re: Re: Re: Painted Black on a H in reply to CNKS, 01-01-2004 19:51:55
Thanks Guys, After all the different tractors I have seen, some have black starter, gen, gas cap, and so on. I guess it doesnt really matter a whole lot.But I will paint it RED. Thanks again
Paul in mich
01-02-2004 19:47:50
 Re: Re: Re: Re: Painted Black on a H in reply to gary v, 01-02-2004 19:41:31
I've talked to a lot of guys at shows who say that they paint the starter, generator, voltage regulator, coil, and some other parts black to give some contrast to all the red even tho all these things were red from the factory.
