fan adjustment
Buster
01-02-2004 06:30:59
Does the nut(in line with the hub) on the back of the water outlet turn and then loosen enough for the whole fan asswmbly to drop down. This is a Farmall 100
F-man
01-02-2004 06:44:55
 Re: fan adjustment in reply to Buster, 01-02-2004 06:30:59
Yes. You need a slender 13/16 open end wrench to get to it. It is a little tricky to get to.
to F-man
01-02-2004 13:02:58
 Re: Re: fan adjustment in reply to F-man, 01-02-2004 06:44:55
I can turn the nut about one turn one way and then back again. It looks like a bolt in front of the water oulet is turning also. maybe I'm seeing things bit if is turning how will i ever get the nut off?
Buster
01-02-2004 07:17:47
You can turn the nut about one turn one way and then back again. It looks like a bolt in front of the water oulet is turning also. maybe I'm seeing things bit if is turning how will i ever get the nut off?
Buster
01-02-2004 07:18:57
 Re: Re: Re: fan adjustment in reply to Buster, 01-02-2004 07:17:47
