560 wide front mounting holes
Colorado Curt
01-02-2004 07:44:12
Yesterday I tried to put a wide front on my 560 and everything was going too smoothly. The narrow front came off with no problems, the wide front (from a 544) rolled into place and everything lined up perfectly. It was too good to be true. When I started tightening the 4 front bolts, it felt like the bolts were bottoming out. I checked the hole depth and there is plenty of room for the bolt. Is it possible that the holes are not tapped completely?
K.B.
01-02-2004 12:55:16
 Re: 560 wide front mounting holes in reply to Colorado Curt, 01-02-2004 07:44:12
I'd agree that the threads are extremely dirty/rusty. Those holes have been directly exposed to 40 years worth of mud. There's no reason why they wouldn't be completley tapped. Don't get too worried, a 544 Farmall front end will bolt up to the bolster. I would worry about the stay rod bracket not matching up with the holes in the frame rails (although I'm 90% sure it does), and if you're planning on using the 560 hubs, you might find that they do not work, but those are just little problems.
old
01-02-2004 08:47:52
A lot of times those old bolt holes get crude in them, I'd run a tap in them and clean them out. Also if they where open holes dirt dobbers love to fill them up spray some PB/wd in them and run a tap in them.
