'66 series tractors,,,
Bryce Andreasen
01-02-2004 19:48:44
Have a 1466 with an airesearch To-4, is there any way to make it sound louder or run higher? Or without having to buy a kit. Also, did all '86 series tractors come factory with turbos, i was looking at used tractors on another site, and one said had an added on turbo, i thaught that once the 66's had them all had them.
MAGNUM
01-03-2004 08:51:24
 Re: '66 series tractors,,, in reply to Bryce Andreasen (Magnum), 01-02-2004 19:48:44
i installed a switzer 3lm 466 on my 1466, and she will talk to ya now!!! when shes working hard she wont drop below 1800 rpms's, the only draw back is comeing off a stop sign, she's a little sluggish, till the turbo gets spinnin' then it'll put ya in your seat
farmallgod
01-03-2004 03:27:11
Take the silencer ring off the turbo, then it will scream.
E J
01-02-2004 21:44:26
You could put a AR.100 exhaust houseing on it and turn it harder their not very expensive.If you where to put a different turbo on a 3LM 466 switzer is a good unit for a IH.
Red Boy
01-02-2004 21:00:23
Yes you can make them scream just by putting on a shorter stack. 1086 thru 1586 came with turbos same with the 1066 thru 1566 also did the 966 and the 986 didnt but they can be added but you cant work them as hard then.
the tractor vet
01-02-2004 20:02:02
Well you could put a HolSet on or a switzer and the 1086 thru 1586 came with a charger but the 8 and 986 did not.
w gatewood
01-03-2004 04:22:02
 Re: Re: '66 series tractors,,, in reply to the tractor vet, 01-02-2004 20:02:02
the 766,966, 786,886, 986 did not have turbos
the tractor vet
01-03-2004 06:17:41
 Re: Re: Re: '66 series tractors,,, in reply to w gatewood, 01-03-2004 04:22:02
I think i said 8and 986's did not and yes i did leave out them toy tractors that are below that and i should have said 766 thru 986 did not have turbo FROM THE FACTORY
CHUCK
09-04-2004 13:11:03
 Re: Re: Re: Re: '66 series tractors,,, in reply to the tractor vet, 01-03-2004 06:17:41
Tractor Vet,a few years ago, while working in Denton Montana, I purchased a complete ERTL -IHC "66" series. All boxes are still sealed in plastic. I have boxes #1 thru #9, inclusive of all models from #966 thru #1566, plus #4590 the COMMEMORATIVE EDITION IHC'S 5,000,000 TRACTOR AND COLLECTORS COIN. Tractor Vet, I am interested in the value of and the best place for selling my collection. Can you help me? Thanks Chuck
Bermuda Ken
01-03-2004 06:40:54
Actually, the Australian built IH 986 "B" series DID have a factory installed, turbocharged, German Diesel engine.
The AMERICAN made 986 did NOT have a factory installed turbo.
the tractor vet
01-03-2004 20:27:54
 Re: Re: Re: Re: Re: '66 series tractors,,, in reply to Bermuda Ken, 01-03-2004 06:40:54
Well i have never worked on one made in the land down under , nobody ever called me to make a service call down there. But i have had ever nut and bolt out of the ones made for around here.
