smta clutch finger adjustment
paul
01-03-2004 05:56:58
Cannot find any adjustment specs in service manual for pressure plate finger adjustment ta or main plate.Overhauling ta and main clutch,I would assume that they are pre set from factory. would like to have input before assembly.Do not want to overlook something so simple.Thanks paul
rebuilder
01-03-2004 10:40:40
 Re: smta clutch finger adjustment in reply to paul, 01-03-2004 05:56:58
Paul: I just helped a buddy intstall a T.A. in a 400. I did nothing to the PPA since they are set from the factory. I belive the only reason you may adjust the fingers is if you were putting used PPA/flywheel back in to account for any wear/play. Measurements in the IT manual though follow as
--back plate(the plate which retains the springs)rear side-to-friction face of pressure plate must be maitained at 19/32" if fingers are adjusted.
--release lever(fingers)height from release bearing contacting surface to friction face of pressure plate should be 1 5/8"
These measurements are in the 400 IT manual but should remain the same for SMTA's since this T.A. fits SMTA/400/450/560/660.
post back if I totally confused you.
lee
01-03-2004 08:06:16
The manual should show a dimension off the flywheel face. I don't have an IH manual for that.
the tractor vet
01-03-2004 06:24:33
The only time i have ever messed with finger hight adjustment is on Deeres and i had to get the set up gauges for that . You might be able to get the spec . from HY Capacity but no promess on that. If i need a clutch heavier then stock i order one and it fits every time.
paul
01-03-2004 07:34:28
 Re: Re: smta clutch finger adjustment in reply to the tractor vet, 01-03-2004 06:24:33
So are you saying that they are pre set from factory??Paul.
TDK
01-03-2004 13:08:45
 Re: Re: Re: smta clutch finger adjustment in reply to paul, 01-03-2004 07:34:28
They are pre-set from factory.But we all make mistakes.Had one recently that was not pre-set,wasn't even close.Set it or at least check it according to specs listed on previous post.
