International 600 650
Paul Stoltenber
01-03-2004 10:10:27
In an old barn, I found an International 600 and 650. Does anyone know what they are worth. They look like they are in pretty good condition (complete, straight, no rust, etc.) I don't know if they run. I've looked but can't fine a price anywhere. I know that the 600 was only produced for one year. Any help would be appreciated. Thanks.
Ron in Nebr
01-04-2004 17:59:42
 Re: International 600 650 in reply to Paul Stoltenberg, 01-03-2004 10:10:27
What they're worth will depend on lots of things. Are the engines stuck? Are the tires good, useable, or junk? Deisel or gas engines? If they're deisels, are the heads cracked? Lots of variables here. Where they're located will also have an effect on their value. If you got them running it would also make them worth more. I'd say the value for one would be generally be slightly more than a similar-condition SWD9. For what it's worth, about two months ago I bought a 650D with a stuck engine for $300.00, poor but useable tires(they hold air). Decent sheetmetal. Got it unstuck and running the first day I brought it home. Still needs some attention, but for what I have in it, it was a pretty good deal. By the way, it takes a pretty decent-sized trailer to transport a tractor of that size and weight!
Paul
01-05-2004 17:06:32
 Re: Re: International 600 650 in reply to Ron in Nebr, 01-04-2004 17:59:42
The 600 is Gas. It hasn't run for about 3 years (it did run before that, I'm told) but is not stuck. The engine looks like it is in pretty good shape. The rear tires are ~50% and the fronts and ~20%. They are all weatherchecked but all hold air.
The 650 is diesel. It also hasn't run for 3 years (it also run before that) but is not stuck and the head is not cracked. The tires are about the same as on the 600. They are located in WI and not far from where I live, so transporting them won't be too bad. Thanks for your help.
