Super A originality lighting question
Dave
01-03-2004 12:53:33
I'm doing a complete restoration on a 1950 Farmall Super A. When I got it it had the flatter sealed beam headlights on it and they looked original to the tractor as best I could tell. I bought the same type to put back on it. But, in Guy Fay's Letter Series Originality Guide, he list that the tear drop lights were used until 1952. If I want to be correct to the tractor do I need the tear drop lights for my 1950 Model, or were the seal beam flat lights an option in 1950? This tractor does have a lot of options to include radiator shutter/temp gauge, belt pulley...
SAm in NS
01-04-2004 05:54:57
 Re: Super A originality lighting question in reply to Dave, 01-03-2004 12:53:33
I have a 53 Super A and the fronts are sealed beam and the back is a tear-drop type. With the difference in lighting between the two I can certainly see why someone would put the sealed beams on. I hope this helps. SAm in NS
Charles Ryall
01-04-2004 07:57:58
 Re: Re: Super A originality lighting question in reply to SAm in NS, 01-04-2004 05:54:57
I also have a 53 Super A with the same set-up as Dave.
Hugh MacKay
01-03-2004 15:12:33
Dave My Super A has tear drop lights and were on it from new. It is a mid 1953 model.
Farmer Bob
01-03-2004 14:06:04
I'd say it's your tractor and you should make it the way you want it. I've always put my trust in Guy's research. Most likely, a former owner installed the "Flat-back" lights because he had them available. Hard to say what it may have had on it off the assembly line other than the tear drop lights.
