engine swap in farmall 460 ,HELP
Jeff Muehring
01-04-2004 06:18:40
I got my doner engine from a 303 combine to replace wore out tractor engine and realised there is no place to add crank case oil on side of block. Only a skinny little dip stick. Oil was added on top of valve cover like in a truck. Any body have this problem.
ChadS
01-04-2004 07:45:33
 Re: engine swap in farmall 460 ,HELP in reply to Jeff Muehring, 01-04-2004 06:18:40
I put a 403 combine engine in a H frame recently,, it had both fill tube and valve cover cap. I don't know much about the 303 engine,, except it is a small ci engine. Is there a place for the fill tube in the block? I made it in to a puller, and put 460 utility sheet metal on it.. looks just like the real thing!! LOL. Not much help here from me,, but other than the tube,, it should go right in. Just got to choose where you put oil into at.. ChadS
ChadS
01-04-2004 08:28:07
 Re: Re: engine swap in farmall 460 ,HELP in reply to ChadS, 01-04-2004 07:45:33
third party image
Here is a picture of the tractor afterthe engine swap, and hood has been built. ChadS
