SHV Width
Bud
01-04-2004 06:25:43
Does anyone know the width of a SHV ( END OF REAR AXLE TO END OF REAR AXLE ). Thanks
Hugh MacKay
01-05-2004 06:36:20
 Re: SHV Width in reply to Bud, 01-04-2004 06:25:43
Bud: I think your best bet here is to start a new thread asking for responces from guys with SHV, even HV, MV or SMV manuals. It will be same manual as non V tractors and should list dimensions for both. The reason I listed all of the above is minimum width should be same. On the non V tractors the H has shorter axles, SH, M and SM are all 84", end to end. End to end on axle housings will be same on all.
map
01-04-2004 14:56:47
Just went out and measaured the Super H
About 88" from the outside of one tire to the outside of the other.
Hugh MacKay
01-05-2004 06:18:04
 Re: Re: SHV Width in reply to map, 01-04-2004 14:56:47
map: Outside of tire to outside of tire really tells nothing. The question is how narrow can the tractor be adjusted for hauling. A Super H with standard axle will be 84" end to end on axles. With wheels dished out you can get them down to about 78"-80", but the axles will be out about 2"-3" beyond tire on each side.
Having said all of this, Bud is wanting the minamum width for hauling purposes of a Super HV, which could well be different. Looking at how the V models are put together there could well be differences. I don't think we have established that, unless your tractor is a Super HV. You however, called it a Super H.
map
01-05-2004 08:23:43
 Re: Re: Re: SHV Width in reply to Hugh MacKay, 01-05-2004 06:18:04
My tractor is just a Super H, no "V"
Bud
01-04-2004 16:43:47
I bet your wheels are installed such that the concave side is facing out( this is the normal setting ).I was told that the width between the ends of the axles is 84 inches.I believe that if you install the wheels with convex ( curves out )side out you can reduce the width by several inches. Thanks
Mike P.
01-04-2004 14:06:03
Not sure about the SHV, but I will go out and measure the SH.
Hugh MacKay
01-04-2004 09:11:53
Bud: The Super H with standard axles was 84", I doubt if the SHV was a lot different.
Bud
01-04-2004 09:29:13
 Re: Re: SHV Width in reply to Hugh MacKay, 01-04-2004 09:11:53
Hugh
Do you know what the dimension from the outside of one rear tire to the outside of the other rear tire would be if the rear wheels are dished in ( concave side toward the tractor. I'm trying to deside if a SHV thats coming up for auction will fit between the fenders of my trailer ( 82 inches ). The wheels appear to be flush with the end of the axle but as I said they are dished in. I think it will fit but its a long drive and I want to be sure.
Thanks
Bud
rustyfarmall
01-04-2004 12:43:53
 Re: Re: Re: SHV Width in reply to Bud, 01-04-2004 09:29:13
Bud, A regular H farmall will fit on your trailer with the wheels dished out, provided that it is equipped with the 11.2-38 tires or the 12.4-38 tires, but the wheels need to be slid all the way in, as narrow as possible. Also, locate the tractor on the trailer pointed forward, with the tractor rear wheels centered between the trailer axles, for the best possible ride. Also, don't skimp on the chains and load binders when tying down to the trailer.
