Turf Tires on a Farmall C?
Tommy H
01-04-2004 12:05:11
Hey, I was wondering if you can get turf tires for a C?
i know, I know, its a farm tractor, its supposed to have lugs!...But it will only be used to bushhog some, maybe pull a 2 bottom plow, or disc a little, and cultivate. So I really dont need the lugs. They would wreak havoc on my St. Augustine!
Im not sure of the Rim size, but ut is the rims size that was factory.
Ed Fisher
01-04-2004 18:36:00
 Re: Turf Tires on a Farmall C? in reply to Tommy H, 01-04-2004 12:05:11
Tommy, you can use hubs from an Oliver 60 I believe to change to a wheel with a bolt pattern mount. Then you can get what ever wheels and tires that you want for lawn mowing. I would try to stay with a tire size that had a heighth as close as possible to the original (9.5-36). It may not be possible to find tires the right size though. Trying to keep the tractor level will assist with keeping the mower deck level. Good luck!
