43 H Magneto
TR @ NH
01-04-2004 13:20:28
Apparentlycoming from the mag I have an occasional chirp that sounds like a spun bearing. Oil in the oil cup doesn't help. With the mag removed there doesn't seem to be a way to get at the shaft to lubricate it—if that's what it needs. Mag works fine so far.
Any ideas?
Nebraska Cowman
01-04-2004 17:52:19
 Re: 43 H Magneto in reply to TR @ NH, 01-04-2004 13:20:28
there are ball bearings in the mag that get packed with grease when you assemble it. Pull the impulse coupler and woodruff key and dissasembly is pretty straightforward.
Tommy H
01-04-2004 13:46:10
Id first make sure its coming from the mag. Its right up there by the Governor, belts and water pump and all.
