Did the 560 come with a 3 point?
DEM66
01-04-2004 13:32:24
There is a sale coming up that I was thinking about going to with a 560 at it. My neighbor told me the 560's only came with 2 point hitches. Is this the case? I was hoping to buy this tractor to pull a 6 row cultivator and 6 row ditcher for corn.
Thanks,
Dan
Steve
01-04-2004 13:43:35
 Re: Did the 560 come with a 3 point? in reply to DEM66, 01-04-2004 13:32:24
Either a fast hitch or a standard drawbar from the factory. 3 point hitches are available now, they bolt on the axle housings and use hydraulic cylinders to lift.
earlschieb
01-04-2004 13:41:29
560s only came with 2 point hitch on them, you can get the 2 point to 3 point adapter and make them a 3 point, you will have to buy or make the place for a toplink to attach though.
DEM66
01-04-2004 19:08:12
 Re: Re: Did the 560 come with a 3 point? in reply to earlschieb, 01-04-2004 13:41:29
I'm only familiar with a 3 point. I was thinking the only differance between a 3 point and a 2 point is that a 3 point has a top link. What is a 2 point to 3 point adapter?
Dan
Slowpoke
01-08-2004 01:09:00
 Re: Re: Re: Did the 560 come with a 3 point? in reply to DEM66, 01-04-2004 19:08:12
There's an IHC 240U two point Fast Hitch with a 3 point Fast Hitch adapter. The adapter arms fit in the two sockets of the two point. There is a large inverted "U" welded between the two arms; on the top of the inverted "U" is a set of ears to accept the top link. The ends of the arms have latches similar to the Case "Eagle Hitch". There's an IHC 350U two point Fast Hitch. Each socket accepts a single arm with a standard swivel ball on the outer end. There is a top link point on the rear end.
There's a '60 Cub Lowboy with a one point Fast Hitch.
ryan
01-04-2004 20:10:20
it has 2 pt. hitch on one side 3pt. on the other so you can use 3pt. equipment with your fast hitch
ken
01-04-2004 18:50:06
earl theres a 560 at the local ih dealer that has a drawbar
