'44 Farmall ''M''-can someone explain
TDK
01-04-2004 21:07:47
Why do M's have two different types of front wheels? Mine is a '44 & has 3-spoke(W-6 type)wheels.I've seen others,both newer & older than mine with same type wheels as 300-450 tractors.Does this have to do with where they were built,etc.?Just curious!
mine
The Red
01-05-2004 06:51:37
 Re: '44 Farmall ''M''-can someone explain in reply to TDK, 01-04-2004 21:07:47
There were 2 styles available for the Hs and Ms. the 3 bolt type and the style where the rim is clamped on the hub with 3 clamps. Mine have both styles.
Hugh MacKay
01-05-2004 02:55:35
TDK: I suspect it has more to do with the fact that someone has changed them since tractor was new. Those 300-450 wheels you speak of didn't appear until in most cases Super series, or about 1950.
TDK
01-06-2004 00:49:39
 Re: Re: '44 Farmall ''M''-can someone explain in reply to Hugh MacKay, 01-05-2004 02:55:35
Hugh,mine has the old style wheels,but i've seen others even older than it with newer style wheels.Thanks for explanation!
