Farmall H hi low range
Lance
01-05-2004 08:23:23
I am purchasing a farmall H with a Hi-Low range. It is not like a TA that can be shifted on the fly. you have to be stopped to switch. Is this an IH product or an Aftermarket product like an M&W or something like that?
Thanks
Vern MN
01-06-2004 08:16:33
 Re: Farmall H hi low range in reply to Lance, 01-05-2004 08:23:23
As per Larry, I have a '44 H that had a Heisler unit put in 1951, It has worked all these years trouble free. This made the H a great tractor on the roads moving loads.
Lowell Andreessen
01-05-2004 11:08:11
Rusty Farmall is right. There was an inveterate tinkerer and machining genius named Harry Heisler who lived near Waterloo, Iowa back in the 1950s. He had several add-ons for tractors, but his "9 speed transmission" was very popular in that farming area (I grew up near him, but never knew him). His invention added a "hi-lo" lever and you ended up with 4 more gears between 4th and 5th. I drove a couple H Farmalls with this transmission...it worked great and was a fun thing to drive. He built a big house on his farm near Cedar Falls, IA, and it is still there.
I'm now having my dad's 1950 "H" restored. After 23 years I found it and bought it last summer. It's already going to be a costly thing, but worth every penny to tool down the road with it. Now I have to arrange to get it to Wisconsin this spring.
I need to find a good set of fenders for it.
Jim
01-05-2004 15:06:40
 Re: Re: Farmall H hi low range in reply to Lowell Andreessen, 01-05-2004 11:08:11
I have a good set of fenders with extenders at Dubuque, Iowa. Need sand blasting and painting but are the original sheet metal thickness not reproductions. $225 at Dubuque, Iowa
Lowell Andreessen
01-05-2004 11:13:43
Ooops. I said Rusty Farmall was right. "Carp" is the one who mentioned "Heisler".
rustyfarmall
01-05-2004 10:31:34
That unit, when in high range, will also speed up the PTO. Be sure it is in low range before using any PTO driven equipment.
Carp
01-05-2004 08:57:26
It is most likely am M&W 9 speed conversion. I believe that another company by the name of Heisler (sp) made something very similar as well.
Lance
01-05-2004 09:00:06
 Re: Re: Farmall H hi low range in reply to Carp, 01-05-2004 08:57:26
How is it a 9 speed. Wouldn't it be a ten speed since you have 1-5th gear?? what gear doesn't it work with?
Dave WV
01-05-2004 09:20:35
 Re: Re: Re: Farmall H hi low range in reply to Lance, 01-05-2004 09:00:06
These units give 2 speeds on the countershaft. You get 5th gear when mainshaft and imputshaft are locked together and this doesn't change with 9 speed units.
Carp
01-05-2004 09:18:41
Steve is right. Since 5th is direct, the extra set of gears doesn't effect it. The M&W kit gives you 4 additional speeds that range in between the speed of 4th and 5th gear. It also gives you a faster reverse.
Steve from MO
01-05-2004 09:14:21
Fifth is direct drive.
