400 block head studs
Bill Evans
01-05-2004 09:18:32
I am rebuilding a 400 engine. I put the head on and torqued the studs, stripped one (upper threads) and a second one broke off in the block. Should a rebuild job also include replacing all the head studs?
Wayne Swenson
01-05-2004 10:34:26
 Re: 400 block head studs in reply to Bill Evans, 01-05-2004 09:18:32
I would ckeck your torque wrench for accuracy (you DO use one, don't you?); those bolts are good for several re-torquings unless they have been damaged earlier.
Bill Evans
01-05-2004 11:43:52
 Re: Re: 400 block head studs in reply to Wayne Swenson, 01-05-2004 10:34:26
Yes we used a torque wrench. But now I'm paranoid. I ruined a good head gasket and don't want to have to buy a third one because I break more studs.
rustyfarmall
01-05-2004 10:28:25
I don't think it is necessary to replace the studs, but on an engine of this age, it would be a good idea to remove the studs from the block so you can do a thorough examination.
