a silencer ring on a turbo,,,
Bryce Andreasen
01-05-2004 19:44:18
Again, you have said to take a snap ring off, and take a donut shaped peice off, and it will make it louder. It is hard to see wich peice to take off. I am looking on an I&T shop service manual. It only has exactly what it is called, so it is very hard. So far what i have found would be the backplate, or the Turbine Shroud. Is this even close?
Disturbed 1066
01-06-2004 08:09:42
 Re: a silencer ring on a turbo,,, in reply to Bryce Andreasen, 01-05-2004 19:44:18
There is not a silencer ring on a to-4. They are used on other turbos to quiet them down a little with out restricting them to bad. If you want your 14 to be louder, I suggest putting a 3lm-466 switzer on it. I have one on my 10 and it sounds like a different tractor than before.
E J
01-06-2004 07:40:33
I have the same ? theirs no snap ring on a TO4 in the air side or donut shaped ring.Looked at two of my spares yesterday the early one does have a flat ring that sets inside the compresor housing maybe thats what their talking about,but no snap ring.
