value of international 240 utility
curt
01-06-2004 12:40:35
I have a chance to get a 57' 240 utility with new rear tires-cluch,throwout and pressure plate. the front bucket with good hydralics. Has a rear PTO.
I would like to get a backhoe attachment for it. I don't have a clue about its value or capablities of a backhoe or if different ones fit.
Antbody help me/ Don't know where to get info.
Thanks Curt
Jeff
01-06-2004 19:53:42
 Re: value of international 240 utility in reply to curt, 01-06-2004 12:40:35
Curt, The IH 240 matches up well with a Wagner 120 loader. Sounds like this may already be the case with the unit you are looking at. Wagner also made a model 65 backhoe that was a perfect companion to the 120 loader when both where mounted on an IH 240 Utility. If you have a good running 240 Utility with a loader on it...it should be worth $3500-4500 depending on the condition of the set. Add a backhoe and it's a $5500-6000 big boy toy.
Jeff
01-12-2004 10:24:15
 Re: Re: value of international 240 utility in reply to Jeff, 01-06-2004 19:53:42
Thank you for the valued info. Anyone in the NH area deal in this?
TY Curt
w gatewood
01-06-2004 18:13:03
the 240 tractors didnt start producton until 1958. they started at serial # 501. ant they were built in louisville ky
