Order Farmall Cub Parts Online
cub idler gear
john
01-06-2004 16:02:23
while rebuilding my 1951 farmall cub engine I decided to change the the idler gear bushing so I removed the old one pressed a new one into the idler gear and now the housing that holds the idler gear to the block won;t go through the new bushing . the new bushing is .015 to large can I hone the new bushing or what. Thanks john
parts man
01-06-2004 16:18:55
 Re: cub idler gear in reply to john, 01-06-2004 16:02:23
John, those bushings are like rod bushings, they have to be machined once they are installed to fit the housing they run on. Take it and the housing to a machine shop/ engine rebuilder and have it reamed to size.
john
01-06-2004 16:43:18
 Re: Re: cub idler gear in reply to parts man, 01-06-2004 16:18:55
partsman do you mean ream out the new bushing. thanks john
parts man
01-07-2004 16:32:20
 Re: Re: Re: cub idler gear in reply to john, 01-06-2004 16:43:18
John, yes, the new bushings will be a little thick to make up for wear on the gear, so they need to be reamed to tollerance.
