ih 504 brake shaft seal
Joe Vurgason
01-06-2004 17:23:28
Im looking for a brake shaft for a ih 504. Its the shaft that the brake and clutch peddles go on to. The one I have, i believe is worn because even though i put a new seal in the housing it still leaks hyd fluid.
((I need to know how the shaft comes out))? (Im new to this tractor but im learning) When I was replacing the one seal i had the clutch pedel off and it seemed like the shaft would slid right out of the housing. Is that true or is there something attached to the shaft?
Thanks
Joe
Randy in NE
01-07-2004 04:18:49
 Re: ih 504 brake shaft seal in reply to Joe Vurgason , 01-06-2004 17:23:28
The first thing that you should do is buy the parts and shop manuals for your tractor. Case/IH and Binder Books have pretty good copies available.
