Clutch disc install
Craig Mullen
01-06-2004 18:07:49
I'm trying to put my IH 340 tractor back together, but I did not originally remove the clutch and the replacement is not marked. Can somebody tell me which way to install the disc since my I&T manual only states "removal and installation is obvious"? Do the springs on the disc go toward the flywheel or the pressure plate? Also, the replacement pressure plate has the finger adjustments painted over like they are pre-set, but should I expect to follow the sdjustment procedure in the manual?
craig mullen
01-08-2004 17:48:32
 Re: Clutch disc install in reply to Craig Mullen, 01-06-2004 18:07:49
thank you both for the helpful information, with any luck I won't hit any other snags!
Catskill Pete
01-06-2004 20:34:10
Never never never trust factory presets on clutch plates etc, always check the settings. The plate may be set for some other application.
the tractor vet
01-06-2004 20:17:27
the spring damper goes to the pressure plate side , the vary best way to put it together is hang the pressureplate and disc on the input shaft and slide it together but first lock the fingers down , this can be done buy layen your pressure plate down on the floor and using your heel push down on one lever at a time and install a 1/4 inch nut between the lever and plate . NOW most times this is done from the rebuilder and if it already done make sure that you get them out after ya start to bolt the plate to the flywheel then ya just slide the tractor together and install the bolts from underthe tractor thru the hole in the bottom this way ya only have to align the pilotbearing.
