Hydralic Pump Help
Red1
01-08-2004 08:58:44
Thinking of installing a M+W pump on a 1948 M.D. With this distributor mounted pump would I need to change the cam gears. The pump Iam getting came off a M.D.newer model I suppose. I know in my year there were no distributor pumps available. I also know putting the pumps on Ms you needed to change the cam. Are the older M.Ds able to handle the Pumps without a problem. If anyone knows how to hook up the plumping for this live hydrlics set up it would help. Actually any info. on this idea would be appreciated. thanks
Dave
01-08-2004 10:48:50
 Re: Hydralic Pump Help in reply to Red1, 01-08-2004 08:58:44
From engine # FDBKM19282 up Everything should interchange without changing front cover or gear.
There is more than one type of M&W pumps.Not sure
which one you are refering to when you say distributor mount.
