WD-9
Old Farmall Dav
01-08-2004 16:21:52
Was wondering the horse-power rating on the WD-9 (diesel), and any other misc. info. on this tractor.
DieselDr.
01-08-2004 18:35:05
 Re: WD-9 in reply to Old Farmall Dave, 01-08-2004 16:21:52
i have a 52 that i pull with and it should be around 80-90hp
Red Rider
01-08-2004 20:08:41
 Re: Re: WD-9 in reply to DieselDr., 01-08-2004 18:35:05
DieselDr, you have to tell me how your getting 80 to 90 horse power out of your D334 WD9. I have a 600 D350 with the overbore in it(370cu) and I can't get over 75hp. Are you saying that you are getting 80 to 90 dyno hp?
DieselDr.
01-08-2004 20:38:42
 Re: Re: Re: WD-9 in reply to Red Rider, 01-08-2004 20:08:41
i sent thepump out and had big plunger put in the pump, and turned the rack as far as it could go. took the injectors into the pump room at work and reamed out the orifics in the injectors, and played with the pump timing-i'm at 6000ft. elev. and i thing if i remember right, i set the pump at 12 degrees before tdc. i weigh apx. 7800 and pull in div 2, and pull around 180 percent avg.
F-man
01-08-2004 17:41:19
Visit oldoakfarmalls.com. There is a complete Nebraska Test Table. The WD-9 was tested twice. In 1941 (46 HP) and 1950 (51 HP). You can link to it from the Tractor Links on this site.
Farmaller
01-08-2004 18:26:05
 Re: Re: WD-9 in reply to F-man, 01-08-2004 17:41:19
WD-9's are fun to play with mine has hand clutch, a little hard to get use to. It also has live hydraulics.
old
01-08-2004 16:47:15
My list says 46HP sorry thats a W-9 not a WD-9 its either 46HP or 51HP my list has 2 HP listed for it
old
01-08-2004 16:45:18
My list says 46HP
