non pressure radiator from a A on a Super A ?
Jerry
01-09-2004 14:06:11
I have a super A that needed a radiator. Well I ended up putting a water pump on too and now I am about to mount the radiator off an A on the super A. Will it be alright to mount a non pressure radiator off an a on it or will I have overheating problems. Thanks for all replies in advance.
Jerry
gene b
01-10-2004 03:33:21
 Re: non pressure radiator from a A on a Super A ? in reply to Jerry, 01-09-2004 14:06:11
The radiators must be the same or they wouldnt interchange. Why would it overheat?
Lewis
01-09-2004 14:36:24
Jerry,
All I can tell you is this; I have been running a radiator off an "A" on my Super A for better than 10 years and the tractor has yet to run hot. This includes hot Mississippi summers of better than 90 degrees, so I don't think you will know the difference, and I am not so sure there is a difference.
Hugh MacKay
01-09-2004 14:19:07
Jerry: Did the Super A have presure radiator originally? I don't believe what you are doing will be a problem. I guess the best advice I could give is try and see.
