stuck ring ?
Andy in Ohio
01-10-2004 10:58:19
Is there any way to get stuck ring loose without tearing the engine apart? Can I squirt something down the spark plug holes to soak? ie; marvel mystery oil, PB or something else? This tractor was overhauled but sat for a while inside[2 yrs] before being started. It starts right up and runs great but smokes a lot on idle. Thanks for any ideas. Andy
Farmall-Nut
01-10-2004 17:32:40
 Re: stuck ring ? in reply to Andy in Ohio, 01-10-2004 10:58:19
Andy, I would try "Kroil" oil. As far as I'm concerned they make nothing better. ED
42FarmallH
01-10-2004 11:07:24
I would try PB Blaster, or Marvel Mystery oil. I used PB to get the W9 engine loose, then used Marvel Mystery oil in the engine oil while running and the rings eventually came loose.
A few cycles of warm up and cool down can also break a ring loose...
