F-20 Pistons
Shawn in MN
01-10-2004 13:23:13
Im just starting to assemble my F-20 engine. One of my pistons got damaged on removal(rust). Mine are Flat pistons and the donor piston that came out of an F-20 has a beveled edge around the top, will it hurt anything to use both styles? I wont be doing a whole lot of work with it or anything. Thanks in advace for the help.
justin
01-10-2004 13:33:24
 Re: F-20 Pistons in reply to Shawn in MN, 01-10-2004 13:23:13
The beveled edge generally denotes that it is a high altitude piston. Check the distance from the top of the wrist pin to the top of the piston and see if they are the same. If not, try to find a piston that matches the ones you already have, or use the high altitude if you have 4 good ones.
JerePa
01-10-2004 21:02:37
 Re: Re: F-20 Pistons in reply to justin, 01-10-2004 13:33:24
Reguardless of which piston you use, the piston weight should be the same.
