checking a TA on a 300 utility
pat,maplehillfrm
01-10-2004 19:19:38
hello all, is there a way to check to see if the TA unit on a 300 U is working correctly or is in working condition, this is on a tractor that does not run but has all parts intact, I was wondering if it would be a big job to see if it is functioning, or functionable, thanks pat
Donnie
01-10-2004 19:45:46
 Re: checking a TA on a 300 utility in reply to pat,maplehillfrm, 01-10-2004 19:19:38
If the tractor engine is not stuck, you should be able to check it. Put the torque handle up in high torque and see if the motor will turn backwards. If it does, its out. Old mechanics trick. Hope this helps.
paul
01-11-2004 05:59:08
 Re: Re: checking a TA on a 300 utility in reply to Donnie, 01-10-2004 19:45:46
Donnie your comment is correct but there is still a possibility that the gears,bearings clutch,and ppa might be worn to a point of replacement and will not perform correctly under load,just thought I would mention that.Paul.
