 Chris: Dan is almost bang on. Your Cub is a 1973. Serial numbers for 1973 start at 240581 and run through to 242745. Your serial number 241257J most definitely falls within the 73 production year. The J signifies that it is a Rockford Clutch and not an Auburn. If you want to learn more about your Cub, then I would suggest the following. Click on the link below and visit the Manual Server. Tons of info. You can also access the ATIS FAQ's, The Best of H.L. Chauvin, and all kinds of other info on Cubs. Two other forums that specialize in all things Cub are: www.farmalcub.com www.atis.net Both are wonderful sources of information. Kurt, if your serial number falls in the 200,000 region then your Cub was built sometime between 1957 - 198231 to 204388 and 1979 when the last Cub Serial number 253685 was built. If your Cub is a 51, then the serial number should fall somewhere between 121454 and 144454. Hope this helps.
