Farmall BN?
Irv
01-11-2004 13:26:20
A friend of mine has a BN. It need some work. I am not familar with it - what years were they built, hp, and features? Thanx, Irv
DaveBN
01-11-2004 16:54:29
 Re: Farmall BN? in reply to Irv, 01-11-2004 13:26:20
Most service parts are still available from your Case/IH dealer. You can buy service manual also. good luck. Dave.
Red Dave
01-11-2004 16:13:39
Built from '41 through '47. Same as a B except 8" narrower rear wheel spacing. Same engine, transmission & final drives as the A. No factory hydraulics, used manual lift for implements or an optional exhaust-powered pneumatic lift system.
I think a total of about 15,000 were made.
Farmallkid
01-11-2004 13:43:13
Not much about bn's in my book but the b\bn are very much the same, i think the bn was a three-wheeler, we have one. It weighed 1,780 lbs it can pull a single 16in plow, rear wheel weights were priced at $14.25 each and fronts were $4.50 each,for 1940 the b was priced at $605. it was made from 1939-1947, it was capable of tread widths of 64 to 92 inches, They approx. 17 drawbar hp and 19 belt hp. Hope this helps.
The book is 150 years of international harvester by ch wendal
